Home > Technical (L322) > 5.0 SC power steering pump.
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Can anybody point me in the right direction for the part number of or alternativel source for a pump. Lakeland Land Rover are shut so I can’t get a part number and I imagine the cost for a genuine new unit will be eye watering. Mines leaking. If you are not part of the solution you are part of the problem!!
Post #549060 1st Apr 2020 10:34am
bruce
The only one I can find non genuine is in Germany, any ideas for a UK supplier? If you are not part of the solution you are part of the problem!!
Post #549072 1st Apr 2020 12:43pm
Pawl
Island 4x4 or Britcar are usually pretty good if you know what part no. you want.
They typically have a range of part "qualities" incl Land Rover, OEM & aftermarket. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #549079 1st Apr 2020 2:13pm
bruce
Thanks, I just need to find the correct part number and I’ll give them a call. If you are not part of the solution you are part of the problem!!
Post #549080 1st Apr 2020 2:23pm
Weegie
I believe it is LR011844
Link here: https://www.brit-car.co.uk/product.php/155...10_to_2012 John
GAP iiD BT-Sold
Post #549081 1st Apr 2020 3:03pm
bruce
Thanks, I spoke to Britcar, unfortunately they only have genuine which is eye watering. I have gone for the Mapco version at £165 from Germany. If you are not part of the solution you are part of the problem!!
Post #549089 1st Apr 2020 4:35pm
Pawl
It probably doesn't help now, but you might be able to get it considerably cheaper via the ZF part number if you can find it (ZF are the manufacturers for land Rover) Paul,
Post #549094 1st Apr 2020 4:55pm
