![]() | Home > Technical (L322) > 5.0 SC fan |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 ![]() ![]() ![]() |
As soon as I stop the car main engine cooling fan kicks in and runs continuously. Car is it only showing normal temperature and the only way to stop the fan is by removal of the 50 amp fuse. Opening the drivers door also stops it any ideas what’s causing it I’m assuming a faulty thermostat but where the hell is that located If you are not part of the solution you are part of the problem!! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3879 ![]() ![]() ![]() |
Their is a Workshop Manual in the wiki solely dedicated to the 5.0l engine, which should answer your questions.
So it appears that the ECT module is faulty but where is it actually located? Any ideas. If you are not part of the solution you are part of the problem!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35839 ![]() ![]() |
lockdown is getting to you Greg..... |
