![]() | Home > Technical (L322) > Faulty CSOV - fix or replace? |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Hi,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3879 ![]() ![]() ![]() |
The CSOV stuck on my 2011 VSE whilst it was still under warranty.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
It might be prudent to confirm that your linkage retaining screw isn't frozen (rusted in?) before ordering the updated linkage kit. However this likely requires the valve to be removed to check thus making for extra work if the valve has to be refitted before the kit arrives. |
Graeme, excuse my ignorance but would a stuck retaining screw mean that the whole unit would need to be replaced? RR Vogue 4.4 TDV8 - 11
A screw attaches the linkage to the shaft so if it can't be undone then the linkage can't be changed. Same for the vacuum chamber attachment screws.
