![]() | Home > Maintenance & Mods (L322) > LED interior upgrade |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Looks great.
Any tips, anything difficult or you would do differently? |
| Panoramix Member Since: 18 Mar 2016 Location: Milan Posts: 22
You need to remove a lot of trim.
| FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101
It looks perfect , has you more pics from the parts and building
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
How do you remove the instrument needles? I pulled them on my original l322 and wrecked the motors - I have the same style one as you now and need to get them off wondered if any different? Current stable:
For the earlier L322 is very very easy broke them pulling out.
I'm sorry FrankN, I didn't. |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Could you list the parts required? John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Only SMD 3.5 LED, soldering iron and patience.
Thank you. |
What’s the safest way? Maybe slide a fork in and gently lever out? Current stable: 2015 5.0 V8 S/C AB 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
If you are removing any instrument gauge needles, you should use one of these to avoid pulling the shaft away from the driving mechanism.
| RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250
Great job Panoramix and kudos for the attention to detail. |
Hi thanks for the tips - what leds did you use as I may do mine can you get different brightness as I had white ones fitted to my old l322 and they were so bright at night but I couldn’t turn down the rheostat as you couldn’t see the green on anything else... Current stable:
| All times are GMT |
