Home > In Car Electronics (L322) > Dead Range Rover
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Dead Range Rover
Has anybody encountered the Parking aid control module issue? Frightening that everything is dead, hard reset doesn’t work and all because of damp in the parking module case. I cannot see wher water has got in, everything else is fine. If you are not part of the solution you are part of the problem!!
Post #551851 27th Apr 2020 6:06pm
stu1
What 'Parking aid control module issue'?
Post #551858 27th Apr 2020 7:08pm
bruce
The parking aid control module located in the rear is prone to water ingress, From where I don’t know but if water gets in to this little black box the vehicle is dead. Nothing, rein, nowt, Censored all, Trying to start it all you get is smart key not found.. I found a fantastic little video that showed the issue and made my day because I would never have found the problem. If you are not part of the solution you are part of the problem!!
Post #551867 27th Apr 2020 8:58pm
rjff
Bruce
There a quite a few threads on the water ingress in the near side rear cubby. It appears to affect several of the units in that space and there is a tech bulletin about a major prevention mod. Would you believe, a piece of plastic covering the units.
If you want to search, here's a starter for you:
https://www.fullfatrr.com/forum/topic4551.html
Might help with other electronics in there. Cheers
Richard
Gap IIDBT
Post #551942 28th Apr 2020 1:30pm
Does the car start if you unplug the PAM ? .
Post #551966 28th Apr 2020 3:40pm
bruce
Yes I’ve seen the bulletin but no sign of damp anywhere else. The inside of the module is horrible, look. Once disconnected everything works fine, whilst connected everything is dead.
Post #551993 28th Apr 2020 6:18pm
stu1
Could be clamping one of the busses
Post #552004 28th Apr 2020 8:36pm
You could always give it a good scrub with a toothbrush and some contact cleaner, might just get it back working (it did for my Sat Nav DVD unit - which looked just as bad) - although those capacitors don't look happy. You have nothing to lose by trying it. .
Post #552009 28th Apr 2020 9:33pm
bruce
I have got a new one for£80. Not worth damaging the wife’s tooth brush. If you are not part of the solution you are part of the problem!!
Post #552022 29th Apr 2020 7:53am
Now put a plastic cover over that Thumbs Up .
Post #552033 29th Apr 2020 9:23am
