Home > Technical (L322) > Fitting a voltmeter into the dash
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi, I intend to fit a voltmeter into the dash so I can keep an eye readily on the state of charge etc.. I've identified an area I may be able to cut out a 50mm circular hole to accommodate one... But I need to remove the panel beneath the steering wheel, the one marked airbag to see if there is enough behind clearance, does it pull off or held with fasteners? Is there danger of detonating the knee airbag etc? Thankyou. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #552553 3rd May 2020 7:27pm
why dont you get one of those usb things with a voltage readout...saves cutting the dash.. ... - .- -.
Post #552554 3rd May 2020 7:34pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
They also do one that plugs into the cigarette socket
Post #552555 3rd May 2020 7:37pm
Gsxr1250dave
I have one of these it's a USB fast charger and has the charging voltage displayed just plugs into the cig lighter.
No fuss no damage or
You could get one of these and just mount it on the centre console and connect to the cig lighter
https://www.ebay.co.uk/itm/324145235726
Post #552558 3rd May 2020 7:47pm
ur20v
A Trap
Leave your gap iID tool plugged in and the volts show on the information display in the dash all the time 👍
Post #552567 3rd May 2020 9:13pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
You could get a usb voltmeter and leave it plugged into the cubby hole or for £15 or so you can get an obd head up display and then have speed, temp and voltage options on you windscreen. 2011 4.4tdv8 Vogue
Baltic Blue
Post #552572 3rd May 2020 10:18pm
DrRob
You can view the volts in the hidden menu area Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552596 4th May 2020 9:37am
something like this ???
loads on ebay,
Post #552597 4th May 2020 9:42am
Gsxr1250dave
That's pretty much what I have in mine BUT mine also let's me play music from my phone via fm tithe car stereo, hence I dont feel the need to rip out the standard infotainment system.
Post #552598 4th May 2020 9:46am
p38arover
Australia
Remove the clock and fit it there. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #552601 4th May 2020 10:38am
Rapiscan
Hi, thanks for all the options offered, I don't have a usb port so the only option would be to have a cigar socket one but the only socket up front is, in the ashtray which I'd have to leave ajar with the thing sticking out, just doesn't seems elegant or tidy.. Rolling Eyes 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #552619 4th May 2020 12:22pm
Rapiscan
Think I'll give the flat surface mounted one off ebay a go for a fiver.. Ta folks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #552622 4th May 2020 12:40pm
Mine mounted in a 2004 TD6.
Connected to a permanent live with a piggyback connector into the front fuse board. Allows me to see the voltage on the car just by looking through the side windows.
Post #552636 4th May 2020 4:00pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Looks good, I have couple of questions:
Did you use a fuse that is permanently live or an ignition switched one? If always on does the current draw hurt the battery over time?
Thanks for sharing your installation. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #552704 4th May 2020 10:08pm
^^. Used a fuse that is permanently on, never had a problem with battery drain caused by it. Been on the car for about eight years to date. Thumbs Up
Post #552716 5th May 2020 8:07am
