![]() | Home > Technical (L322) > MOT Brake Testing Question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
dont let them use a roling road matt...
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
Haven't had my FFRR MOTed yet but when i had my subaru impreza they did a road test for the brakes. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Paul the local MOT guys did the same for my Defender for the last 11 MOT's - if no 4wd rolling road then it's road tested 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Has to be 4 wheel Rowling road or de-accelerometer! Anything other will result in a big bill for MOT centre for new transfer box and other it's! He's talking |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
4 wheel rolling road or road test - has been ever since the RR was launched and permanent 4 wheel drive in the LR's.
It makes you wonder whether the fact RR's go through gearbox and associated parts is actually down to mechanic incompetence rather than an issue with the box.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
dont take it to them as they should know better you cant put an alltime 4wd on a 2 wheel rolling road it must be road tested ....incompetent |
sassanach Member Since: 03 Feb 2011 Location: south west Posts: 12 ![]() |
i think you will find that modern "rolling roads" are quite capable of testing 4wd vehicles,what happens is the opposite wheel on the same axle is reversed by the rolling road,therefore the differential rotates NOT the propshaft. |
I already replied to you when you posted on the other topic about this - the RR is permanent 4wd so the front and rear axles are connected together via the transfer box. Anything that happens on one axle should happen on the other. In the event that the rolling road turned the wheel in the other direction this would confuse the hell out of the ABS DSC - this would result in a skewed reading because the DSC would cut braking to try and stabilise a "stationery" vehicle. At the end of the day Vosa are quite clear on this: "Any permanent four wheel drive vehicle/vehicle with centre differential should NOT be tested on a two wheel rolling road" If the MOT tester can't follow this BASIC instruction then what about the rest of the MOT!? ![]() |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Always road test with a Tapley meter, never rolling road - no excuses. |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Had my Range Rover MOT'd this morning and a decelerometer was used for the brake test |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Well she has passed with flying colours |
nice result matt... |
