![]() | Home > Technical (L322) > L322 battery drain |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
That's a handy looking bit of kit & not a bad price. Unfortunatly, it's on back oirder otherwise I would have bought one. They also do a miniblade version. 2003 Range Rover Vogue TD6 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Ive seen some horrific accidents caused by an inadvertent short with a spanner. The worst one the guy got acid in his eyes and burns to his face from the explosion, he lost total sight in one eye, most of his sight in the other eye and was scarred for life. That was on a Merc Sprinter with a leisure battery installed under the drivers seat. As you say, you shouldnt understimate 900+ CCA, it can do a LOT of damage to the people nearby and the vehicle. BMW i3 Electric Car
In stock on Amazon https://www.amazon.co.uk/SovelyBoFan-Multi...amp;sr=8-1 BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
No problem
As I said - not in stock, although the mini-blade one is. 2003 Range Rover Vogue TD6 |
Try here LOL
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I used a simple multimeter and clamped the probes into the battery connectors, left the wires running under the back of the bonnet so that I could use the MM from the top side of the bonnet, enabling me to close the bonnet. Leaving my bonnet open meant that it took bloody ages for the car to power everything off before I could see a proper indication of the drain and this made the work far more time consuming. With the bonnet closed, it was much quicker to work through it all.
Thanks AJ - he probably buys them from CPC & sells them on. |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Hi you must have a different obd port, on my L322 the cover hangs down any way. What I did find is that the GAP IID Tool was drawing about 2 amps if I left it in. After checking amp draw on shut down I ended up with .109 amps. Fairly acceptable I hope , now I leave the car if parked a while with a solar charger. |
On mine the cover clips into place, or hangs down. For some some reason the cover has a couple of connector pins on the cover. I simply cable tied the cover to the under side of the dash, holding it in the open position.
