Home > Maintenance & Mods (L322) > Rear Diff options
sigmaes
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Rear Diff options
Hi all,
I was doing the DIff service and the oil from the rear diff came out looking like mud, I can feel alot of sand like debris in the diff still, I'm guessing it's toast.
I have the non ETM Diff are there any aftermarket options? do I have the same Diff as the LR3?
Thanks
Post #553973 15th May 2020 3:56pm
Have you checked the diff for backlash and worn bearings, I've had diffs full of mud before and it's usually just the bearings that suffer, the backlash and wear of the gears wasn't an issue... Doubt there are aftermarket ones, not a big enough seller... Not sure on compatibility between Land Rover species..! Good luck Pete
Post #554053 16th May 2020 12:40pm
GraemeS
Australia
I'm surprised that the diff isn't an e-diff as I thought all 4.2 SC were fitted with e-diffs.
The diff isn't the same as an LR3,
Post #554114 16th May 2020 9:03pm
sigmaes
thanks for the info, I was really hoping that the only difference between the RR and LR3 diff's was just the output flange.
I'll be removing the diff and taking to a local shop to have it checked.
Post #554197 17th May 2020 3:01pm
