Home > Technical (L322) > L322 battery drain
ricky25
United Kingdom 2003 Range Rover Vogue Td6 Rimini Red
L322 battery drain
Hi, my L322 has developed a fast battery drain when standing for a couple of days. The battery is virtually new. Please can some kind soul please advise me how to check the fuses one at a time with my multimeter without disconnecting the battery ? Thanks in advance !
Post #553838 14th May 2020 10:17am
You have to disconnect the + terminal of the battery, put your meter in line with the + post to read amps drawn, then remove fuses one at a time until you find the one that has the drain. Make sure the meter can handle the amps and whatever you do don't start the car or even put the ignition on, it will fry the meter...!!
Be very careful removing and replacing the fuses, where there are blank holes, its easy to return a fuse to the hole next door...!!
Good Luck... Thumbs Up Pete
Post #553841 14th May 2020 10:36am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Much easier and safer to use a clamp meter that goes around the battery lead, lots of items take a while to go back to sleep when the power is restored, a clamp meter being non invasive stops the wake up and false readings. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #553842 14th May 2020 10:38am
ricky25
Thanks for your suggestions. I was hoping to do this without disturbing the battery and losing a lot of settings as a consequence. I'm sure that before I did this from inside the car by the fusebox but can't remember how or what I'm looking for in multimeter readings !!
Post #553848 14th May 2020 11:17am
AJGalaxy2012
With the car parked up for a while, bonnet open etc, put a clampmeter around either battery lead, look at the discharge current. If it's excessive, start to pull fuses one at a time until the drain disappears, you've then found the culprit.
Ive just helped someone with a Focus ST with a random battery drain issue, it turned out to be the dashboard staying awake which was a software issue in the standard Sony Radio.
J BMW i3 Electric Car
Post #553852 14th May 2020 11:58am
He said with a multi meter not a clamp meter, agree one of those is more ideal... Thumbs Up
What settings do you think you will lose because apart from radio channels and seat memory you don't lose much else..!! Pete
Post #553853 14th May 2020 12:06pm
AJGalaxy2012
The problem with a multi meter approach is that as stated the modules will wake up and be taking current for quite a while, another major problem is the power on surge is highly likely to be sufficient to blow the fuse in the meter, most multi meters max current is circa 20 amps. The Focus I looked at a couple of days ago it's power up surge was in excess of 100A recorded on the clamp meter.
I notice in your earlier post you suggest disconnecting positive, much safer to disconnect the negative if going down the meter route.
Post #553855 14th May 2020 12:29pm
I presumed that if he was clever enough to use a multi meter he could handle a dangerous 12v lead...... Laughing Pete
Post #553856 14th May 2020 12:34pm
AJGalaxy2012
Accidental touching the bodywork with the spanner on the positive terminal is the issue. Much safer to disconnect negative. BMW i3 Electric Car
Post #553857 14th May 2020 12:51pm
It can't be that hard even a total idiot like me has done it hundreds if not thousands of times in the last 45 years of working on cars. I have never touched the body with a spanner that was touching a positive post and back in the day the negative one on really old cars.
Thanks for your health and safety lecture... Rolling Eyes Pete
Post #553860 14th May 2020 1:36pm
its nice to see a few sparks now and again.. Shocked Laughing ... - .- -.
Post #553864 14th May 2020 2:00pm
https://www.fullfatrr.com/forum/topic47332.html?highlight=drain .
Post #553866 14th May 2020 2:19pm
AJGalaxy2012
No health and safety lecture, sorry you see it that way. Just because youve done it thousands of times is irrelevant really, the fact is you get it wrong once and theres a potential situation developing with no need. Whats the problem with disconnecting the negative? surely you would agree its a safer way with no penalty in terms of time or difficulty?
I have no problem with anyone doing it as they please, I merely offered a suggestion to the OP that negative was a safer way.
Sorry to seemingly have caused offence.
AJG BMW i3 Electric Car
Post #553875 14th May 2020 4:11pm
No need to disconnect battery, use one of these below.
Simply pull a fuse, insert that fuse into handle bit of device, plug into space where you removed the fuse and read current flowing through fuse position.
Assuming everything is off any current will be to earth.
You have to wait until the car goes to sleep before you start and when plugging in device be patient to allow current through fuse to stabilise if required.
Just work through each fuse in turn.
Available from here. https://cpc.farnell.com/tenma/ten01046/cur...pd-mi-alte
Post #553895 14th May 2020 5:58pm
Brian Considine
It may only be 12v but there is a hell of a lot of current to hand - current that can be very dangerous indeed.
Many people under estimate (& come a cropper) the possible dangers & risks associated with low voltage high power electrical systems. 2003 Range Rover Vogue TD6
Post #553931 15th May 2020 8:52am
