![]() | Home > Technical (L322) > Odd non starting issue |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Perfect, AGM it is. Now to decide on 019 or 020, £149 & £179 respectively for Yuasa.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 376 ![]() ![]() ![]() |
It needs to be a 019, the 020 is too large to fit easily. There are a number of useful articles in the wiki to help as the battery housing is difficult to access and the battery is heavy and cumbersome. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Cheers - 019 AGM YUASA ordered from Tanya.
goopta Member Since: 04 Jul 2014 Location: Aberdeenshire Posts: 14 ![]() ![]() |
Just went through this. Intermittent starting 08 3.6. Would get nothing but a click on turning the key occasionally.
Battery isn't hard to change yourself. Put the bonnet in service mode. Prise the clips out of the gas strut bottoms to release them from their pins and lift the bonnet up and lock it with the fixing with a hole in it that swivels to a pin and locks the bonnet in a near vertical position. I removed earth and live cables. Tied earth cable forward out of the way. Put the live sideways as much as possible released the two retaining clamps and got a small steps to gain height and leverage. I also had a large square of high density 3" foam just in front of the battery compartment as piece of mind really and just humped it out. Replace with new and it isn't an issue. Bit heavy though. I would be cautious if outdoors and a bit windy putting the bonnet into service mode. |
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Very easy to check if its an earth issue, put a jump lead between the negative in the battery and something mattalic on the engine. If it starts reliably and doesnt when you remove it - chances are you have a dodgy earth strap. |
Cheers all. Did the battery myself (easy job to be honest) and haven’t had the starting issue since.
