Home > Technical (L322) > TD6 Starter motor location
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Sorry if this sounds a stupid question - but... where is the starter motor on a TD6 as I'm damned if I can see/find mine. My starting issue is getting worse and basically I'm going to remove the starter as I'm just getting a 'click' 'whirr' sound now Sad
Post #59570 9th Apr 2011 4:49pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'm sure it's on the N/S of engine (righthand side as you look into bonnet)
Post #59572 9th Apr 2011 4:58pm
mercs600
Yes - that's what I thought as the positive lead from the battery goes down there - also the other side is taken up with the exhaust and the turbo.
Does anyone have any tips on how best to remove it ? Wink
Post #59577 9th Apr 2011 5:24pm
Richcl
Never removed one, but usually remove the live lead and a couple of mounting bolts. A lot depends on how much you have to remove to get to it and the space to work around starter.
If nothing in the way, 10-15 minutes to remove (famous last words.........)
Post #59581 9th Apr 2011 6:27pm
mercs600
I'm dubious that its an easy job due to its location under the manifolds Sad
Post #59588 9th Apr 2011 8:12pm
