Home > Maintenance & Mods (L322) > Air suspension inactive |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 |
It would appear that my compressor is goosed
9th Apr 2011 6:54pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
A simple check is to look at the wiring that runs around the front struts, on mine they had worn through against inside of wheel/tyre. Just turn the steering full lock to lock and look underneath the wheelarch.
9th Apr 2011 6:59pm |
Ive checked the wires and they look ok
9th Apr 2011 7:35pm |
You say your compressor is goosed? How have you come to this conclusion?
9th Apr 2011 9:12pm |
Ah I see
10th Apr 2011 8:07am |
Fix what? You don't know what the problem is yet? You could go to the dealer for the diagnosis = £120+ You could then fix whatever the issue is = £??? You could then go back to the dealer for the code to be reset = £120+ That's a minimum of £240 - but without knowing the cause the cost could be completely open ended. D |
10th Apr 2011 9:21am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
When my EAS failed the lights on the hieght adjust button went out and if I flicked it up or down to raise/lower the suspension, the relevant light came on then went out again and nothing happened. What happens if you hit the access height button on the drivers door? By the way mine was the common valve problem (blocked) on the compressor in the boot (@ £7 item if you do it yourself as shown on a thread somewhere on this forum). Steve
11th Apr 2011 1:11am |
The message came on when I was towing the trailer, so it was in standard height and locked. When I tried to adjust it once the trailer was unhitched the corresponding light would flash. Now that I have unplugged the compressor in the boot the lights have gone out and will not come back on This valve sounds promising, Ive done a search and cant find it |
11th Apr 2011 8:34am |
Why have you unplugged the compressor!?
11th Apr 2011 11:15am |
I disconnected the compressor to test it I am aware the suspension is locked in normal height when a trailer is attached and I did try to adjust it one I had unhitched it |
11th Apr 2011 12:20pm |
How did you test it? You can't just apply 12V to it as it's a 3 way plug iirc. |
11th Apr 2011 12:26pm |
I know, I found out when I pulled the plug apart So at present, I still dont know what is wrong with the damn thing |
11th Apr 2011 12:29pm |
Well, going back to the beginning - you need to get the fault read. The dealer will be able to assist you with this, or EAS Activate. Some independent garages will be able to read and clear the fault too. |
11th Apr 2011 12:37pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
check you havent blown the fuse as well theres a large fuse in the boot in the right hand side and one in the glovebox "RANGEISM WILL NOT BE TOLERATED"
11th Apr 2011 1:49pm |
