![]() | Home > Technical (L322) > 2008 Dash removal |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1866 ![]() ![]() |
Its a little fiddly, but you can just remove the centre trim, column shrouds and lower kick panels, and access the switch that way |
JPJ64 Member Since: 23 Jun 2017 Location: Newcastle upon Tyne Posts: 49 ![]() ![]() ![]() |
Did you realease the screws under the centre air vent? |
Both centre console side panels off
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
So it can be got at from the bottom? Current cars
No, need to work through the column shroud and space from the centre panel
Yes Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Mikey I take it the sill cover is pried off as I can see no fixings to undo. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Yes, held in place with 4 plastic clips |
Thanks easier than I thought.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
While it's apart, replace the bulbs in the upper footwell lights. I was never able to remove the lights as per the handbook instructions. Use quality bulbs or LEDs. I replaced mine with Chinese LEDs and they have gone into flicker mode (as have most of the others I replaced with LEDs from the eBay LED kit). Ron B. VK2OTC
Mikey got there in the end. A few variations and I needed to lift the top section of the dash to get one of the speedo trims out but essentially I am ready for the new switch. As soon as it arrives I will know if my new car goes or not. ![]() Can the switch be tested now that it is out with a multi meter? Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
