Home > Technical (L322) > Drivers Seat Positions - Fuse Keeps Blowing
pcourtney
in the last 4 days I have blown a fuse every day, it works for 2 or 300 miles, then the fuse goes, I spoke to my friendly local indy garage, and he has not been very helpful when asked to diagnose, saying they do these types of things all the time, but then he is not the best person for electrical problems I have found in the last 10 years
he muttered under his breath that it could be the Seat Relay
has anyone had similar problem to me, and managed to find out what the problem was, I have used my GAP IID tool, but no faults come up, certainly nothing that indicated "Seat Relay" - so that was not much help either
nothing about Seat Memory ECU being on the blink either
could it be the cheap switches in the seat, maybe a short, a pain to troubleshoot, apparently you start with the headrest motor first, and check if both wires are showing ground on your multimeter !
I also saw this - which I'm gonna try as well
https://www.fullfatrr.com/forum/post22035.html
Post #555299 25th May 2020 9:06pm
roverguy7
United States
I've seen several times where the seat switch bezel becomes loose/broken and allows the wires to short out behind there.
I would start by pulling the bezel and switches off and taking a good look at the wiring.
Post #555416 26th May 2020 8:29pm
