![]() | Home > Maintenance & Mods (L322) > 4.4 tdv8 inlet pipe seal part no. |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
If you mean the green seal that sits inside the plastic piece that slides over the throttle body then form what I understand, this is not available on it's own, you have to buy a complete part including the pipe. Seems ridiculous as this part will lose it's ability to seal properly over the years, more so if the part is taken off from time to time to clean the throttle butterfly. 2011 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Sounds like a challenge for someone to find a source for that seal. I bet with enough digging it can be bought on its own... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Need to check the size but the part number is similar
This seal is missing the lip that the original seal has, it's easy to remove and check, just make sure you put it back in the same way it came out as I suspect the lip presses against the throttle body as pressure builds up. Place it the wrong way and it would allow the pressure to pass by causing an air leak. I'm doing this from memory so I'd advise you check just in case I'm talking out of my backside |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
4 of these used as inlet manifold to head gaskets on a 2L engine so very likely to be much too small. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3866 ![]() ![]() ![]() |
If anyone can supply an old one as a template sample, it might be worth a chat with this place ??
Mike - that is a bloody brilliant idea!! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Sounds like a good idea, although probably better to use a new seal as the template. I imagine there are a few of us on here that would look to buy the seal if it could be made 2011 TDV8 Vogue SE |
I would definitely take a couple.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1335 ![]() ![]() ![]() |
Go on Mike, look what is waiting for you!!!
Big question Kevin,.... is it running any better since you cleaned it out ??
I’m like Mike, wanting to do it but can’t decide when to do it |
To be honest Mike, not really. It might be a bit smoother on pick up. The throttle butterfly was absolutely caked though along with the MAP sensor. If you wonder if yours need doing just take the MAP sensor out and have a look how contaminated it is. Cheers Kev. |
I do that every time I do an oil and filter change (every 6 months irrespective of mileage ).
