Home > Technical (L322) > DPF failure to regenerate - AGAIN!! (AND AGAIN!! UPDATE)
Page 2 of 3 <123>
Dolphinboy
Hi Stan, yep thought of him but he has expressed his reluctance on the forum at dealing with this sort of thing (unless you want to Craig? Razz )
He sends his to the same LR indie who fixed it last time and can't get me in for a month.
Post #558120 18th Jun 2020 1:10pm
DrRob
MJ Fews got any space for you?
Steve Norman in Shepton Mallett is legendary LR mechanic too (like Craig!) https://www.tandsnorman.com/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558125 18th Jun 2020 1:49pm
Dolphinboy
Mj Fews are the ones who can’t do it until July! Have got someone to look at it tomoro so we’ll see what he comes up with.
Post #558133 18th Jun 2020 3:23pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi
How did you get on?
Steve
Post #558343 20th Jun 2020 10:53am
Dolphinboy
took it to an indie who looked and couldn't find anything really obvious. however he did say the parameters hadn't been re-set from when the sensor and inlet manifold was changed 1400 miles ago. He thinks it may have been the ECU being confused by too many incorrect readings and not allowing a regeneration to take place.
Am keeping a keen eye on how it goes. The DPF reading was re-set.
Post #558376 20th Jun 2020 4:41pm
DrRob
What did he do to reset it and could you have done it with your IID? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558393 20th Jun 2020 7:25pm
Dolphinboy
No the IID tool couldn't (or I didn't have the skills/knowedlge) reset it. He said he re-set the parameters (not sure which). He used a (Matrix? I think) machine to read codes and check readings etc.
He was the one who cleaned my DPF and has a very good garage which does everything from mechanicking (is that a real word?) to tuning, paint shop etc. He had a Morgan in there, a lotus and some other sports car so he's obviously quite trusted by owners.
Basically the number of demanded regens has been re-set to zero, along with the soot reading. Interesting the oil/fuel dilution has gone up to 3.1 from 2.05 already.
Not sure this is going to be a fix but we'll see.
Post #558515 21st Jun 2020 8:18pm
DrRob
Did this cure it? Hope so Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560050 3rd Jul 2020 8:36am
Dolphinboy
Hi Rob, only had a couple if journeys since the reset, but on the 2 x 50 mile motorway trips this week it has performed 100%. In fact although the soot level went up to 9.6g, it did a passive regen down to 8.4 at one point. I haven’t checked the figures since yesterday but will do today and report back.
But essentially, yes, no probs so far. I will ask the garage which parameters he reset.
Post #560052 3rd Jul 2020 9:25am
Dolphinboy
UPDATE!!
Twisted Evil Twisted Evil
bloody thing has got a yellow DPF full warning again on Tuesday, only 3 weeks after re-setting the inlet manifold parameters. Did a motorway run (it has done a mix of motorway and urban all the time) to regen and it came down by 3g but not on the same motorway run back!!??
No faults showing on IID apart from yellow triangle
initially Reading 24.5g of soot/8,500 demanded regens!! went down to 19.6g - I think it's got to be software or ECM related. incomplete regen status now 1 as opposed to Zero earlier.
This was 1 July:
This is 21 July:
Oil dilution 3.39
soot conc. 24.5g
incomplete regen status - 1
no of demanded regens - 8825
Weds 22 July 1128 hrs
Oil dilution 3.53
soot conc. 24.6g
no of demanded regens - 9825
Weds 22 July 1130 hrs
Oil dilution 3.54
soot conc. 19.6g - so a partial regen done!
no of demanded regens - 10161
Weds 22 July 1225 hrs
Oil dilution 3.54
soot conc. 20.3g
no of demanded regens - 11407
Weds 22 July 1242 hrs
Oil dilution 3.66
soot conc. 20.8g
no of demanded regens - 12,577
Fri Weds 24 July 1130 hrs
Oil dilution 3.78
soot conc. 21.7g
no of demanded regens - 14,285 Shocked
I have a number of possibilities:
1. defective seal on the EGR valve block
2. Inlet manifold swirl valve failure (new one fitted in March 2020!)
3. sensors related to the DPF Regeneration or even the DPF assembly
4. JLR released a software uplift for the emissions control/DPF Regeneration. may need this?
5. leak between two of the sensors in the exhuast system that measure dpf soot levels
6. The Exhaust Gas Recirculation (EGR) valve not closed.
7. turbocharger NOT maintained in the fully open position
8. The DPF software fault - DPF co-ordinator module faulty or either DPF supervisor module, DPF fuel management module or DPF air management module.
9. ECM Differential pressure sensor fault.
Anyone got any other possibles?
Post #562607 25th Jul 2020 2:04pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
56700 demanded regens in 3 week is about 1 every 30 seconds!!
must be a fault somewhere but i wouldnt know where
hope you get to bottom of this
Post #562608 25th Jul 2020 2:25pm
Dolphinboy
56,000 was over longer than 3 weeks Laughing
looking a the Iid as I drive, it does go up by dozens every second, sometime hundreds in a minute!! its definitely a ECM thing I think. what baffles me is that it will regen sometimes but not by much (last time it went from 25g to 9.6g) but only 3g on the last run.
my indie is stumped and the LR dealer (non-franchise) doesn't know either.
Anyone got a Technical contact in LR who might be able to give some guidance/direction?
Post #562609 25th Jul 2020 2:35pm
Dolphinboy
UPDATE No. 2!
So, took her into Dick Lovett at Melksham for an fault find examination on Friday. They admitted they had never seen this before and They found no fault codes and so they did a PCM update and a test drive but failed to find a solution. Fault still there! bizarrely they then suggested that the only thing they could do (as the computer had run out of ideas?) was to do the updated (v2) Turbo Oil drain for several hundred pounds. I asked how that was going to solve a DPF problem as 1. My vehicle didn't smoke and already had the first fix done satisfactorily, and 2. This wasn't relevant to my fault so Why would I pay all that money?
They then say the only thing they could do was raise a Technical case with LR which would involve me bringing the car back to them in late sept and they would have the technician drive it again with LR head office techs asking questions and reading data. Not sure how that is any different from what the tech did in the first place. Will also cost several hundred pounds! (£168/hr)
The situation is this: the car WILL regen at times but only drops 3-4g then stops, while the sensors show over 1,800 regens attempted in 10 mins. It has attempted regens even whilst under the required speed and whilst standing still at lights!.
I have my own suspicion that it's most likely to be the DPF co-ordinator module faulty or the DPF supervisor module which controls the DPF fuel management module or DPF air management module.
BTW,
The service at Dick Lovett was very good. I asked to see the Tech for a sitrep after 90 mins and to their credit they brought him out and we went through what he had done and his thoughts (not a lot). They also only charged me for 1 hr when it was 2.5. So £168 to tell me they don't know what to do.......
Also, they got me an instant test drive on the New defender which was nice but my wish spec (HSE plus explorer pack, pano roof and tow bar) was £65k!! Shocked It was a nice drive and not bad for a 4-pot but small rear boot space.
Anyway, anyone know any chief Techs at LR I can talk to ?
Post #563985 9th Aug 2020 12:20am
gettingold
Have you spoken with Steve @ T & S Norman, just past Shepton Mallet?. Thumbs Up Hunt for a L405 is on.
Post #563987 9th Aug 2020 7:27am
Dolphinboy
Hi getting old. No I haven’t - will do Monday. Thanks for the tip . Why do you recommend him? What’s his particular edge? Thumbs Up
Post #563994 9th Aug 2020 8:36am
Page 2 of 3 <123>
