![]() | Home > Technical (L322) > 4.4 tdv8 coolant pipe parts |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
The part you show comes as one piece from the suppliers. It has the juunction piece to the left with the two small pipes off and the large pipe on the left. It also has connectors to each. Cost is about £80 from Duckworths. Speak to Rob, he should be able to identify. If I can find the receipt I'll post the part number tomorrow if it's on there.
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
This depending on vin.
https://www.fullfatrr.com/forum/topic48509...roken+pipe 2011 4.4tdv8 Vogue
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
As above, a one piece item |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Indeed! Last thing I need is this blowing and taking the engine out. All the chords are wet so must be failing inside 1995 4.6 v8, green/tan (long gone)
Might be worth doing the radiator while they’re at it - is that a big job?
Update - found the part was replaced 20k ago with the genuine part listed above (LR029140).
