Home > Maintenance & Mods (L322) > Is this a first.....
Changed tyre size in the CCF file with the IID, this threw a P0610-43 fault which put the CEL on and it wouldn't clear..
After talking to Pat he suggested a hard reset, this was done, faults cleared, and then taken for a drive....
Disgusted to find this list of faults when rescanned....
A blank page, I've never seen this before... Shocked Shocked Pete
-Click here for Thread-
Post #558733 23rd Jun 2020 2:57pm
What, not even the air quality sensor ? Wink .
Post #558735 23rd Jun 2020 3:04pm
pcourtney
faulty IID -- send it back Smile
Post #558736 23rd Jun 2020 3:08pm
As long as the air quality sensor isn't under my seat...!!!
I did think it was faulty so read the faults on my mates which is on the drive...!!!
This is an amazing fatty... look at some of the dates and it's telling you what will break next month...!!!
Dash showing no faults.... Shocked
L322 - Range Rover 2008
Vehicle scanned on 23-06-2020 15:47
Using IIDTool BT V3.0 B2643
AAM-Audio Amplifier
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( at 209066 km )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
( on 20-06-2020 15:36:08 at 209066 km )
IPC-Instrument Pack
B1A75-15 (2Cool Fuel sender 1 circuit - General electrical failure - circuit short to battery or open
( on 20-06-2020 15:37:58 at 209362 km )
U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
( on 28-06-2020 15:11:28 at 209066 km )
LCM-Light Control
0xD Redundant inputs contradiction fault
0x003C Unknown
0x52 Check brake fluid fault
0x5A Brake pad fault
0x5B Washer fluid level fault
0x79 Right dip beam headlight defective
0x7B Front right sidelight defective
0x7C Front left direction indicator defective
0x7E Front right foglight defective
0x7F Front left foglight defective
0x81 Right high beam headlight defective
0x8C Left tail light defective
0x8D Right tail light defective
0x90 Rear left direction indicator defective
0x91 Rear right direction indicator defective
0x92 Rear left foglight defective
0x93 Rear right foglight defective
0x0098 Unknown
0x99 Licence plate lights defective
PAM-Parking Aid
0x4 Rear centre right ultrasonic sensor
PBM-Parking Brake
U3000-16 (2Cool Control module - General electrical failure - circuit voltage below threshold
SASM-Steering Angle
U0300-55 (2Cool Internal control module software incompatibility - System programming failure - is not configured
( on 20-06-2020 15:35:54 at 0 km )
TCCM-Transfer Case
U0073-88 (2Cool Control module communication bus off - Bus signal/message failure - bus is off
( on 20-06-2020 15:35:54 at 209362 km )
U0155-87 (2Cool Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
TCM-Transmission
U0155-87 (6D) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 20-06-2020 15:35:54 at 209066 km )
TMC-Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
VIM-Immobilizer
B1B01-87 (2E) Key transponder - Bus signal/message failure - missing a message
( on 28-06-2020 15:15:27 at 209066 km )
U0155-87 (2C) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 09-07-2020 17:20:13 at 209306 km )
U3003-62 (2Cool Battery voltage - Algorithm based failure - signal compare failure
( on 20-06-2020 15:36:07 at 209390 km )
 Pete
Post #558738 23rd Jun 2020 3:15pm
strange...when i put 21'' on my westie i changed the wheel size and had no problems , in fact as far as i could see nothing was different.. ... - .- -.
Post #558739 23rd Jun 2020 3:27pm
As we know Stan, they all have there own little foibles.... Pete
Post #558740 23rd Jun 2020 3:32pm
mjdronfield
How is the wheel size used by the systems? I would have thought rolling diameter would be near identical with the correspondingly adjusted aspect ratio tyres fitted... is it used for traction control etc?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #558744 23rd Jun 2020 4:01pm
Not too sure... this was mine before I adjusted it, it wants to know a lot....
 Pete
Post #558748 23rd Jun 2020 4:25pm
mjdronfield
Wow, must use it for like tyre slip calculations and all sorts of things.
Probably a good thing you updated it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #558751 23rd Jun 2020 5:01pm
