![]() | Home > For Sale & Wanted > [Wanted] Upper Tailgate for 2008 L322 Vogue 3.6 V8 |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 ![]() ![]() ![]() |
If the body shop is warranting that work then £230 is a pretty good price. |
biggles3124 Member Since: 03 Mar 2012 Location: Andover, Hants Posts: 103 ![]() ![]() ![]() |
Bonjour M. Chapeau!
Yes we are, I’m on the south coast. Even your revised price isn’t bad, especially if any replacement upper needed a full paint. |
Thanks you are probably right. Still hurts to pay nearly £400 to repair and paint that metal strip beneath the glass. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
In my experience no bodyshop will give you a guarantee that rust won't bubble through from the inside again, the rust has had to pass through a folded and sealed seam at the bottom of the tailgate, there is no way to remove this without cutting it open and replacing the metal, IMHO once you can see evidence of rusting then it is too late, you can repair what you can see and put as much anti rust inside it as you can but it won't kill all the rust or hold it back for long...
Sage advice, I had a cosmetic job done on mine for a couple of hundred quid (that included blowing in some scratched panels) last Oct, slight bubbling is coming back already. I suppose it entirely depends on what you want out of your car and how much money you want to spend on it. Mine was / is almost at the recycling end of the value curve so keeping it going and looking semi presentable is the priority. But then again, it is a bit of a hobby car and not strictly needed for transport. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Mine was replaced by the supplying MD when it started bubbling at only 3 years old.
