![]() | Home > Technical (L322) > Range Rover 4.4 TDV8 crank sensor change |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3876 ![]() ![]() ![]() |
Two questions please....
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 ![]() ![]() ![]() |
Hi
Thanks Andy |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
...and worth considering changing the starter which tend to go around 70-80k miles if you're doing this
I am not very well qualified to answer, but can you see the turbo actuator ?? is it possible it is sticking ?
Can the actuator motor be put through its motions without actually driving . It would it be a disconnect and move manually. I've driven today to work and back and not a bean of trouble . I will try again tomorrow.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Codes are all listed in the workshop manual. In the wiki for free download |
Hi
