![]() | Home > Technical (L322) > 4.4 tdv8 flat spot? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
You may be experiencing the peculiarities of having a small and a large turbo?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
For the record, the primary turbo is the bigger one. |
Map it... Tis very good at getting rid of that irritating lag! |
Perhaps they have clutch packs with more plates and / or different material. The parts list for the HP26 shows many variations depending on the application. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Surely the rest of the driveline (downstream of the t-case) has to deal with the same engine power but through a far lower gearset when in low ratio so, on the (rash) assumption that most FFRR don't get to use low ratio in anger, a mild remap isn't going to cause problems to the drive train?
Not after the CV joint has done 100k miles! Thats more where the issue lies... |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 ![]() ![]() ![]() |
I have always seen 700Nm as the max for that gearbox, which other applications use it at 1000Nm? Always found it strange that RR managed to get it right on the top limit of the supposed maximum , so genuinely interested. Thanks |
The 8HP90 is rated at 900 for petrol engines and 1000 for diesel.
