|  | Home > Maintenance & Mods (L322) > Solar battery charger |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548      | I've been considering it for my camper. Depending on your needs, an 80W panel gives you 5+ Amps on a decent day for most of the day. Let's say 40Ah which is not too bad. That could go a long way to keeping the battery charged.
|  13th Jul 2020 8:15pm |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808      | Living in West Australia most of my camping is done in remote areas totally off-grid so a solar charge system is pretty much a requirement. The simple solution is to get a folding panel with a charge controller like this https://www.ebay.co.uk/itm/100W-Portable-M...Sw3bZcOMwx   Fitting a second battery in the rear with a charge isolation relay is the next step. We are lucky here that used household solar panels can be picked up for A$20 which linked to a decent MPPT charge controller can keep you in power indefinitely
|  14th Jul 2020 12:39am |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Go camping to a site with electrical hook up.
|  14th Jul 2020 6:50am |
| Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 214      | Thanks for your replies - seems as though a hook-up will keep SWMBO happy! 👍 L322 TDV8 4.4 - current
|  14th Jul 2020 6:59am |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | I had to do the same. Hook up saved the day   | ||
|  14th Jul 2020 7:36am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | JLR will wake up one day and realise the potential of the glass panel in the roof.
|  14th Jul 2020 9:39am |
| Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428    |
 That's about a tenner each in GBP. Whats the reason for them being de-commissioned ? Is it because their efficiency has dropped off ? 2003 Range Rover Vogue TD6 | ||
|  14th Jul 2020 12:11pm |
| Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802    |
 Audi used to have that option on the A8, but all it could do was power a small fan and I think the Prius has/had it as an option as well. The problem is that even if you leave it all day, it won't generate a huge amount of power, but agree that it's a missed opportunity. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold | ||
|  14th Jul 2020 2:27pm |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808      | Brian Considine
|  15th Jul 2020 1:01am |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | ^ Very impressive, unfortunately solar doesn't work in rain.  | ||
|  15th Jul 2020 7:42am |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808      | It does work in rain and cloud but obviously not as well, It does not work in the dark. 2007 TDV8 VSE
|  15th Jul 2020 7:51am |
| Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428    | Thanks for explaining the situation in Australia.
|  15th Jul 2020 9:14am |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587    | I have what is supposed to be a 160w folding solar panel for camping.  I doubt the rating.  On a sunny day (most days) the max I get out of my panels is about 7.5A - that's with a PWM controller - into my 2 x 45AH deep cycle AGM batteries in the RH rear corner (bigger batteries won't fit).
|  18th Jul 2020 6:54am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
