Home > Technical (L322) > TMC problem - solved!
Finally got round to checking the fact my TMC wasn't working. Turned out the antenna connector had a large air-gap between it and the module i.e it wasn't connected!!! Whistle
I can't imagine how or why this could have happened as it clips in with a significant clip, but all is now well!!!
Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #60363 14th Apr 2011 5:16pm
Turnover
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hi whereabouts was this aerial connector as I'm having the same problem.
Cheers
Chris
Post #262766 2nd Jun 2014 2:08pm
My TMC problem is the gap between transmitter and receiver , about 12,000km Big Cry 2008 MY Supercharged
Post #262885 3rd Jun 2014 2:36am
Turnover
Laughing I wouldn't have a clue how to solve that one.
Post #262968 3rd Jun 2014 10:29am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Very Happy But seriously folks... Where is the connector? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #262970 3rd Jun 2014 10:38am
off side cubby hole [i think]
info should be in the WM ... - .- -.
Post #262976 3rd Jun 2014 12:03pm
Its on the near side (of a UK car). Pull off the left hand (as you look at it from the back) side cover and if memory server, it's above the wheel arch. Looks like a fag packet sized box.
Of course, this was so long ago, it might actually be somewhere else completely! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #262999 3rd Jun 2014 4:14pm
Nomad
Thanks for that. It was where you said. LHS rear compartment. It's got TMC on it in big letters which was a bit of a giveaway. Rolling Eyes . Unfortunately for me it all looks well connected so this doesn't solve my problem.
Next I need to take the upper tailgate inside trim off to check if the TMC antenna is properly connected. I seem to remember reading that the trim comes off with a strong pull but I'm nervous about breaking something. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #263003 3rd Jun 2014 5:16pm
Turnover
I managed to get that cover off without breaking anything Surprised
There is a red module in there with a coax cable and a single cable. I think this is just a pre amplifier for the TMC module. I don't know where the aerial is. Still looking......
Cheers
Chris
Post #263152 4th Jun 2014 11:23am
hope this helps,
Post #263154 4th Jun 2014 11:28am
Turnover
Yes I had found that but it seems there is a bit of confusion in the workshop manual. The text that you posted says the aerial is located in the RH rear glass but both back glass windows contain the TV aerials. So the TMC module on the tailgate must connect to the rear screen somehow. This detail isn't contained, unless I've missed it, in the workshop manual.
Is there a more detailed manual that details the wiring of the individual modules?
Cheers
Chris
Post #263232 4th Jun 2014 5:07pm
