Home > Maintenance & Mods (L322) > 4.4 tdv8 high pressure pump noise
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Tying to chase a noise/vibration at around 2500rpm.
Having a listen under the bonnet, how noisy should the fuel pump be?
Even at idle mine is the noisiest thing under the bonnet.
Post #562160 20th Jul 2020 9:35pm
kevinp
I've often wondered that on mine. I think it's very noisey, clicky, ticky if you know what I mean.
Post #562188 20th Jul 2020 11:56pm
JNC
Do you get any noise/vibration around 2500?
Noticeable between 2 and 3k?
Post #562190 21st Jul 2020 12:05am
kevinp
No mate I don't. Bare in mind the second turbo usually kicks in at 2500rpm.
Post #562196 21st Jul 2020 2:43am
JNC
Bumping this. Would anyone mind recording the noise of their HPFP through the rev range?
Idle and slowly between 2000 and 3000 rpm.
I'm sure mine is abnormally noisy. It is not causing any running issues/fault code but there is vibration around 2500 rpm.
Post #573256 17th Nov 2020 8:22pm
JNC
To add to this;
Today I fitted a pump from sdv8.
Same noise. Mad
Post #573380 18th Nov 2020 9:28pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Not sure how much use this will be, but I recorded this the other day as I wasn't sure whether was a noise at idle or not:
It's not through the rev range, sorry, just at idle, but maybe useful. I'll do another one through the rev range if I remember.
Post #573391 18th Nov 2020 10:03pm
JNC
Bit of back story to this.
When I bought the car earlier this year it had a vibration from 2k rpm that got worse at 2500 and was gone by 3000.
Can feel throughout the car.
At partial throttle it also made loud clatter sound.
Shortly after I had coolant level warning and the fan had cut through coolant hose. Damaging the fan.
That was the clatter noise.
Coolant pipe repaired and new fan fitted. Bought a branded Denso. Britpart box turned up.
Since then the vibration has remained.
I have lived with it as before and after those rpm it is fine.
Work has been a little quieter so have had time to mess around with it.
Tried injection pump today to no avail.
Also ran it up with drive belt disconnected. Also no change.
I have ordered a fan pulley unit so will try that. Fan spins true but maybe bearing was damaged?
Post #573393 18th Nov 2020 10:20pm
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
I also suffer from the irritation of the ticking and clicking. Will also record tomorrow at both idle and faster. I do get an element of vibration but will confirm at what revs again tomorrow. My fan does wobble a bit when not engaged but runs true when engaged, is this normal ?
Glad in a way others have the same ticking, couldn’t find anything anywhere else on the web. Hoping it is a common noise and not something untoward. Let’s hope we find an answer.
Post #573395 18th Nov 2020 10:45pm
Siftah
I think it'd be a great resource for the forum if we had a library of noises/videos like this, what sounds normal for each engine and what doesn't, I'm sure it'd help when diagnosing problems.
I guess many already know what sounds normal and what doesn't but personally, the "right" car came up for me before I'd had a chance to listen to few (damn Covid!) so the only TDV8 I've ever heard up close is mine and hence, I don't know if it sounds normal or not! Smile
All I can say is it runs great and there's no warnings, nor engine faults logged on the GAP tool (there's codes going back 10k KM's but nothing engine related), so I think the engine's probably ok :\
Post #573399 18th Nov 2020 11:00pm
JNC
I will get a recording of mine tomorrow.
I can’t believe it is normal. It’s a noticeable vibration apart 2500rpm.
Very minimal ticking compared to your average Diesel engine.
Post #573400 18th Nov 2020 11:12pm
Iamhim
United States
If you have vibrations around 2500 check front drive shaft. Mines did that then eventually broke🥴
Post #573411 19th Nov 2020 6:07am
kevinp
JNC, I did a cold start the other day and while looking under the bonnet everything was quietish. Then after about 10 minutes of idling the pump went really loud. Do you think the fuel cooler has a valve on it that suddenly opens and the pump has to start pushing fuel through it and that could be the noise? Clutching at straws here.
Post #573437 19th Nov 2020 12:27pm
JNC
I took it for a drive this morning. It is definitely quieter. There is still vibration at around 2500. But no noise as previous.
It had definitely got louder from when I bought it.
Obviously the 2 issues were separate but made prominent by one another.
It does it stationary so that rules out driveshaft.
Post #573439 19th Nov 2020 1:03pm
kevinp
Vibration can only be caused by something spinning or wobbling. Have you checked all the pulleys are running straight? Do the drive belts run smooth? I've heard the crankshaft pulley can fail. Look to see if it wobbles at all.
Post #573446 19th Nov 2020 2:23pm
