Home > Technical (L322) > Leak from above the front diff
coopss
Next issue! When having a poke around underneath to try and find the source of this vibration (no luck), i found a very wet front diff. Seems to be coming from above the diff but can’t see anywhere near enough.
A long shot, but any known oil leaks in this area? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #562290 21st Jul 2020 9:49pm
Danwilderspin
Rear output seal which is higher up on the diff? Have you cleaned it up with brake cleaner topped it up and gone for a short drive to see if you can source it that way ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #562296 21st Jul 2020 10:28pm
GGDR
if not the diff itself, the secondary turbo sits above the diff
. Cheers, Greg
Post #562301 21st Jul 2020 10:55pm
GGDR
coopss any update on this?
. Cheers, Greg
Post #566272 4th Sep 2020 12:26pm
DrRob
I had 2 oil leaks around that area:
1) Secondary Turbo
2) Oil pump plug.
Both rectified at Rovertune with 1) new turbo Big Cry and 2) plug sealed.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #566279 4th Sep 2020 3:17pm
coopss
It’s not using any oil at all and there is nothing on the floor after sitting for a few days.. it’s also had both new turbos.
I have an endoscope so will have a look over the weekend 1995 4.6 v8, green/tan (long gone)
Post #566335 4th Sep 2020 10:05pm
