Home > In Car Electronics (L322) > Vogue se problems |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Hi Mike,
24th Jul 2020 7:38pm |
Mikeglr Member Since: 08 Jul 2020 Location: London Posts: 8 |
I’ll post one tomorrow, I’m sure I should be able to but I can’t seem to find it |
24th Jul 2020 8:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7623 |
It uses a hard disk for the sat nav, so no drive / slot for an external disk.
24th Jul 2020 8:26pm |
I don’t seem to get any info like that, it just asks for coordinates (longitude/latitude) nothing else |
24th Jul 2020 8:34pm |
Have you got it in off-road mode? Current: 2011 FFRR Vogue SE 4.4 TDV8
24th Jul 2020 8:43pm |
That’s a possibility as we was toggling through the settings before I bought it, I’ll check in the morning and post a couple of pictures of my screen |
24th Jul 2020 8:59pm |
2011 Range Rover Vogue SE 4.4 TDV8
24th Jul 2020 9:48pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
I had something similar where the postcode option wasn’t there - turns out the country wasn’t set to UK. Changed the country to UK (same screen as the entering the address) and the postcode option appeared 1995 4.6 v8, green/tan (long gone)
24th Jul 2020 11:44pm |
Morning guys, thanks for all your help, turns out it was in off road setting, all sorted now 👍 |
25th Jul 2020 9:32am |
Did you sort out the Bluetooth pairing. There is nothing that can't be fixed with a hammer😜😜
25th Jul 2020 9:39am |
No not yet, not only will the phone not detect it, but also the remote for the RSE is not operating the screen’s either, I’m assuming that it connects using Bluetooth 🤷♂️ |
25th Jul 2020 9:47am |
That’s good then.... as above, just the Bluetooth left?
Have you checked the rear cubby to see if all the connections are good to the BT module? There is nothing that can't be fixed with a hammer😜😜
25th Jul 2020 10:15am |
I’ve had a quick check, taken everything apart and blew in the terminals all seems fine, it’s got six months warranty so I’m hoping they’ll change it if its broken 😬 |
25th Jul 2020 10:30am |
