![]() | Home > Technical (L322) > Alarm sounding |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
To keep the neighbours happy you could also disconnect the sounder until you figure out the issue.
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
Where is the sounder, I thought it used the horns, I would like to disable inside sensors to help diagnose problem but cant see how to do it as they always seem to set themselves.
Should be not far from the bonnet button in the gap between the main firewall and the inner firewall, RHS, near the wing. .
Thanks just waiting for it to go off, as a thought can I disable to internal cabin sensors by taping over vents in roof fitting, or if i unplug then will the car lock okay ?
So no alarm last night, lets see if it lasts.
