Home > Technical (L322) > 2011 tow wiring set up
Fat Lad
First post 3 days into Fatty ownership Very Happy
Hello all, done a bit of searching but can't find anything specific. I have a 4.4 2011 VSE new to myself and have an issue with the tow electrics I am trying to resolve.
I have functioning Brake/Fog/Indicators but nothing on the side/tail lights. Have probed about a bit and have proven there is no voltage coming through to the connector in the bottom left of the wheel well in the boot before the loom then goes off to the right somewhere.
My searching has revealed it appears the 'up to' 09 cars had a separate tow module but it seems a different set up in the later cars? Does anybody know what module controls the tow electrics? Anyway to 'reset' it?
Again, I have searched but there doesn't seem to be a separate fuse for just the tails on the tow wiring circuit but maybe I am wrong?
Anybody got any info on this setup? It is the original 'from the factory' LR kit.
Hoping to tow the camping trailer this weekend but at this rate it'll be daylight manoeuvres only Very Happy
Anybody got a wiring diagram or workshop manual?
Thanks guys, Forum seems awesome, happy to be here!
PS ( proven fault on a separate trailer board and also working trailer lights on a different car)
Post #564467 13th Aug 2020 2:18pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
No direct experience as I just plugged mine in when I fitted them and they worked !
Sooo, have a look in the Wiki pages, down near the bottom, you should find electrical diagrams lurking in one of the 2010-2012 pdfs Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #564469 13th Aug 2020 2:38pm
Bushy30
I had an extract Very Happy
https://www.fullfatrr.com/gallery/albums/u...ockets.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #564471 13th Aug 2020 2:41pm
Baltic Blue
Welcome Fat Lad....love your choice of car Rolling with laughter
You will find the full WM in the Wiki, available as a free download to members.
Post #564472 13th Aug 2020 2:47pm
Bushy30
Oh No ! here comes the Blatic Blue Brigade Rolling with laughter Rolling with laughter Rolling with laughter Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #564474 13th Aug 2020 2:54pm
Baltic Blue
Not many true Baltic’s...very exclusive Rolling with laughter G reg 2.5VM Vogue Portofino red 1991- 1999
Post #564475 13th Aug 2020 3:00pm
Fat Lad
Blummin awesome - cheers chaps!
I do like my BBFFRR I won't lie...
Post #564476 13th Aug 2020 3:03pm
Fat Lad
Just thought i'd close this off for any future 'searchers.'
I had a good look through the WM etc and there was quite a bit of referencing to the 'Trailer Module'. However, having searched high and low (and where the manual said) I couldn't find the thing anywhere. I stumbled upon another thread with identical issues where the chap said he gave in and took it to his indy who changed a fuse and hey presto problem solved.
It appears that the later cars don't have a separate module and that there are individual fuses in the glovebox fuse compartment for each trailer circuit. Trailer sides on a later car are F27 10A iirc. I swapped it out for a spare at a garage on the A1 while the missus grabbed a Costa. Very Happy
Should have read the owners manual...
If the other handful of issues get solved this easily I will be a very happy man. On the plus side we covered about 400 miles without fault and absolutely loved the waftyness of it all.
Post #565127 21st Aug 2020 3:54pm
DrRob
Good to hear! They have their foibles but most are well known and can be sorted...
There is a lot you can do in terms of preventative maintenance:
Replace 4 inlet hoses if they are the crappy originals
Change all oils if not done so including the "sealed for life main gearbox"! Pile of rubbish. Get it Megaflushed
Make sure coolant top hose is not weeping
Check Adaptive Dynamic wiring for chaffing
Bin locking wheel nuts
Oil cooler leaks in V of engine and underneath? Replace O rings and/or gaskets.
Rear arches
List goes on Rolling with laughter
My history: https://www.fullfatrr.com/forum/topic44115-75.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565128 21st Aug 2020 4:02pm
Fat Lad
Cheers Rob,
Most of that is on the to do list for sure Very Happy
I do everything to my own cars and I intend to do everything possible to this one too. She's far from perfect but was a good price and as far as I can tell was looked after by the main dealer that supplied it to it's one owner.
Full service kit ordered this morning.
Any recommendations for who to use for the megaflush? Nearer to Cambridge the better but willing to travel.
Post #565131 21st Aug 2020 4:11pm
DrRob
Megaflush = use Ian Bodsworth who is a mobile guy so comes to you Thumbs Up
Call him on 07770 638023. He’s a busy guy but good Thumbs Up
He’s thorough, tidy and shares his knowledge and passion for Land Rovers Bow down
Did mine and 5 others on a marathon Saturday on my drive in 2019:
Post #565157 22nd Aug 2020 7:41am
