![]() | Home > Technical (L405) > Slight noise. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
I take it not then..... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
hoses maybe Mark? ... - .- -.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 157 ![]() ![]() |
I think member LT has had his L405 in the dealers for months with similar noise item? |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 615 ![]() ![]() ![]() |
i just turn the volume on the radio up and all them bad noises disappear........ |
Thinking it’s engine speed related, I’m going to have a hunt over the weekend to see if I can pin it down. Somehow feels like it could be steering pump or something on the front.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Had a good listen to mine Mark, the noisiest thing seems to be the high pressure fuel pump but that’s more a mechanical noise, there is if I’m super critical very slight engine vibration through the low rev range but I just put that down to it being a Diesel engine. They don’t have a steering pump in the traditional sense, it’s an electric motor on the steering rack, but still lots of stuff belt driven on the engine so could be one of these. If you can replicate it stationary you could try dropping the belt off then running, but only very short duration as you have no water pump / alternator. Good luck with your search. |
First time I’ve had a listen with the bonnet open.
