![]() | Home > Technical (L322) > L322 expansion bottle failure? |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
I've got a little bit of a problem with the coolant in my bmw powered v8 (2003)
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Did not know there was a relief valve, that's what the pressure release cap is there for. The V8`s run higher pressure than the TD6 and are well known for expansion tank failure. Buy a new tank and a diesel pressure cap with number 140 on it as opposed to 200. Hopefully, there is no other problem apart from a split tank. The only other place it can leak is from a water connection or the air bleed screw 2007 TDV8 VSE
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I’d be looking at the radiator, they are well known for sludge in the lower galleries causing what looks like pressure building up.
Thankyou for the replies.
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
You sure it shouldn't be blanked?
Thanks Spud - now that is interesting.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1325 ![]() ![]() ![]() |
I've had a few britpart parts and find them unfit for purpose. |
PCF000033 2006 4.2 SC |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 615 ![]() ![]() ![]() |
Spot on ![]()
