![]() | Home > Maintenance & Mods (L405) > Connecting a battery charger |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Not a problem, just connect it to the positive and negative post under the hood and you are good to go.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352 ![]() ![]() ![]() |
I thought it was good practice to use an earth point on chassis and not direct to the -ve post? I'm sure I've read that on here a few times ??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135 ![]() ![]() ![]() |
The workshop manual says the posts under the bonnet.
Cool. I use my 13pin towing electrics to charge battery via a ctek adaptor off the forum shop |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798 ![]() ![]() ![]() |
I’ve connected mine directly to the battery under the spare wheel for years and with several FF’s without any issue. MY23 D350 HSE
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
A Ctek 5 amp charger will have to work hard , the 10 amp would be better . Even the 10 amp has to left for 48 hours before it shows fully charged . |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431 ![]() ![]() ![]() |
Like Dr Rob I bought an adaptor from the forum shop and charged through the towing electrics, all fine and easy to do. Only Range Rovers since 1988 |
Unfortunately with He deployable tow ball, the electrics are not accessible when it’s stowed. |
FFRR64Royal Member Since: 18 Jul 2020 Location: Saltash Posts: 130 ![]() ![]() ![]() |
DrRob, are these still available? |
Might need to invest in a new one....had my original one for a few years now and has been perfect for our normal car batteries |
Just seen the Shop advert ![]() |
My 5 has been fine - but I only ever really use it as a maintenance charger and not to revive a dead battery. |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Recently bought one of these. For the cost, £38. I'm very happy with it. Will recharge batteries of everything from motorbikes, cars and 4x4s. https://www.ringautomotive.com/en/product/RSC806
Chaps, has anyone come up with a genius solution to attaching the CTEK connector to the remote battery posts?
