Home > Technical (L322) > have i got all the sat nav bits
pretlove
ive just brought a job lot of sat nav parts for the ff and i just wanted to check that ive brought everything i need other than the loom.....
sat nav screen,
TV tuner,
Satellite Navigation,
GPS Navigation,
Radio Tuner.
amplifier.
im just double checking with the bloke ive brought it from to see what else i get with it but for now this is what im sure is included "RANGEISM WILL NOT BE TOLERATED"
Post #60855 18th Apr 2011 2:13pm
gps antenna?
..and a 'how to' manual... ... - .- -.
Post #60856 18th Apr 2011 2:16pm
pretlove
ill check with him and see if the antenna is included...as for the how to ive got to source that for myself...thanks scarey "RANGEISM WILL NOT BE TOLERATED"
Post #60858 18th Apr 2011 2:22pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
You will also need the speed and heading input unit - speed is usually either a speedo head counter or taken off the propshaft, There should be an electronic compass built into the nav computer unit but I have no idea how you check. Speed input is very important for accuracy of the positional calculations especially at the high speeds you can achieve on the road and for when you loose the GPS signals close to tall buildings, in tunnels and underpasses and offroad under trees. This allows the computer to calculate a dead reckoning position when there is no signal. It is possible to use the incar GPS without these inputs, you loose the accuracy 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60868 18th Apr 2011 4:24pm
dan_uk_1984
The speed signal is taken from the ABS ECU, how it interfaces I'm not sure. Rave will tell you which data bus it goes through.
Post #60881 18th Apr 2011 7:20pm
pretlove
brilliant thanks guys.....the bloke said that everything i need is there apart from the loom so ill have to ask him if the speed things there as well if not ill have to run it off of standard gps for now..
ill check rave dan that sounds like a good idea "RANGEISM WILL NOT BE TOLERATED"
Post #60885 18th Apr 2011 7:58pm
pretlove
ok ive just got a messege back with a list of parts that im getting so not all the bits i was after are there
monitor
tv tuner
gps navigation system
radio tuner
so by the looks of it i need the amp as well as the gps antenna and the speed thing Crying or Very sad "RANGEISM WILL NOT BE TOLERATED"
Post #60916 19th Apr 2011 11:05am
can you not use your existing amp .. ... - .- -.
Post #60920 19th Apr 2011 11:20am
....and ,it might be worth considering this option.
http://www.rangerovers.net/forum/viewtopic...468b9d3abd ... - .- -.
Post #60921 19th Apr 2011 11:22am
pretlove
maybe ill be able to use my amp im not sure....i dont like or get what his done there as he allready had nav ...but each to there own i suppose if i went the aftermarket route i would have gone for the units they sell that look just like the oem sat nav but im really after the real deal as it just looks right and allows me to keep my multi changer Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #60922 19th Apr 2011 11:32am
pretlove
has anyone on here retrofitted a sat nav if so does anyone have a link to the thread as ive searched but cant seem to find it.... "RANGEISM WILL NOT BE TOLERATED"
Post #61125 20th Apr 2011 12:37pm
SteveMFr
Site Sponsor
Seems to me there was a song in the 70's: 'Will it go round in circles' Laughing
You might want to re-read your old thread - it's all there: http://www.fullfatrr.com/forum/topic4784.html?highlight=satnav
Quoting myself from your thread:
SteveMFr wrote:
I've retrofitted a nav to mine.
http://www.fullfatrr.com/forum/topic2737-45.html 2nd post down.
I took much more apart than you'd have to. With the retrofit harness, it's basically plug n play.
To get the system up and running you need:
- the monitor
- the nav computer
- the radio module
- a gps antenna (can be universal auto unit sold on ebay for Audi, BMW, etc- but must be waterproof)
- a wiring harness
You don't need either of the amps - it will be the equivalent of your present system w/o.
I assume someone has offered you the lot for GBP150 or the like? Make sure you don't wind up with:
- a monitor that has issues - they're not hard to come by so this is less of a prob
- a tv module for a 4:3 screen - newer ones can be coded for 16:9 by unsoldering and reprogramming an eprom, older ones can't
- a mkIII nav computer with a bum laser (the norm more than a good laser)
- a radio unit with one or more channels gone (also the norm)
These bits are relatively dear when in good shape - as the problems they have are not uncommon so they are sought after replacement parts.
And what are you going to do for a harness? Get back to me if you need help...
The Alpine system that Scarey linked to cost over $2000... To each his own is right.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #61133 20th Apr 2011 1:36pm
pretlove
hi steve thanks for your help ive managed to get the lot for £300 but there is no amp and no harness ...i knew i had spoke before about this but could not for the life of me find the thread so thanks "RANGEISM WILL NOT BE TOLERATED"
Post #61145 20th Apr 2011 3:45pm
SteveMFr
Site Sponsor
Yaa, dunno why, but search don't work so good here...
I can get you a plug n play retrofit harness.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #61163 20th Apr 2011 10:03pm
pretlove
great how much £££ also are you sure my amp will be fine ....im sure i have an amp here is the pic of whats in the rear nearside panel of my hse
Post #61165 20th Apr 2011 10:30pm
