![]() | Home > Technical (L322) > have i got all the sat nav bits |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
will the gps antenna from a rrs fit on the mk3 system? "RANGEISM WILL NOT BE TOLERATED"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
i should think so, any gps antenna should work as long as you have the correct plug..
thanks scarey ...have you got any pics of your install also do you know if this is the amp on my hse ![]() www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
aint got no pics of mine ...i tend to stay away from that compartment as i would probably start taking things out and i wont be able to put it back together....mines a touch screen setup so it'll be different?.. ... - .- -.
I have to call on the harness...GBP 175ish IIRC
I'll take your word on it, Steve. You are def qualified as a BM54/amp expert. That'll teach me to open my yap too quickly. |
thanks steve and steven |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
Sorry Steve, I do not know - but guess the answer would be no, as even the fixed level goes through the output stage (the fixed level is still amplified). However, as in this configuartion, only two of the four output stages are used, depending on which chips have failed, you may be able to work around |
