Mine similar staining, perhaps not quite as noticeable [car done 109k].
A couple of days ago, I drained the gearbox oil and replaced it. While it all looked very fresh, only 2.75l came out and 4.25l went back in [I know more is held in the filter and torque converter], so I expect the staining is a slight weeping of gearbox oil.
It might be worth checking gearbox oil levels - its quite a quick job [20 mins on a ramp] but the oil is expensive [make sure you get LR approved 8-speed oil] and use someone who knows how to do the job [i.e. running through the gears while filling].
I'm not proposing to do anything other than keep an eye on it. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
