Home > Maintenance & Mods (L322) > Tracker Locations
FFN
Tracker Locations
Good afternoon,
I understand why LR wouldn't want to advertise where a tracker is fitted in the vehicle. However, I'm both experiencing a battery drain and my vehicle paperwork indicates a tracker is fitted but I don't have the details - e.g. serial number - that as a new owner I could register it.
So, are there "common" locations for the tracker on the L322 that I could narrow the search? Laughing
Kind regards,
N
Post #567026 14th Sep 2020 3:16pm
AJGalaxy2012
For very obvious reasons, I'm sure nobody, especially L322 owners would publicise this information. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #567028 14th Sep 2020 3:24pm
FFN
Fair point.
On closer inspection of my paperwork I found the "Customer Registration Form" which contains the serial number and installation position Wink
Post #567035 14th Sep 2020 4:04pm
CS
Software problems can cause battery drains on 322s. On my 2012 WM the first time it was the fuel burning heater software (is it under 5 degrees in Shetland yet?) and the second time it was the central locking software. In each case the battery was completely flattened. The solution was to have the dealer do a diagnostic check and then deal with the software fault. It seems that battery discharge in that way can cause it to be unable to hold charge properly in future, and I was told that this could be tested only once the battery has been fully charged. The first time the battery was no longer viable (about a year old), the replacement was OK.
So I suggest a diagnostic check, if you need a main dealer to do it then presumably Aberdeen is the nearest? Only Range Rovers since 1988
Post #567040 14th Sep 2020 5:36pm
FFN
CS,
Thanks for this useful information. I've raised a separate post for the battery drain and the steps I've tried so far. Just purchased a GAP Diagnostics IID tool so will run a full scan as a priority!
Cheers,
N
Post #567042 14th Sep 2020 6:06pm
