![]() | Home > Technical (L322) > Throttle failed |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Throttle pedal is effectively a switch , had to replace mine on a earlier one, my foot slipped on the pedal as it was snowy and I broke the pedal assembly, the pedal had come off and i was left with the plastic tube dangling out. It's a simple plug & play unit. Have a look and see if theres breakeage on th throttle. Just bolts in with a serial plug if memory seves correct.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1345 ![]() ![]() ![]() |
There are plastic cogs in the throttle body that can strip their teeth. I think a couple of members have had to change theirs. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Andy
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 ![]() ![]() ![]() |
Thanks - the throttle body could be it. I'll post how I get on. The car is away with the mechanic now.
