![]() | Home > Maintenance & Mods (L322) > Water ingress with pics |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Water ingress |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Cheers have you checked all 4 of
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Hi, I recenty had wet boot floor, and water under compressor, with also wet rear speakers. I unbolted top trunk door hinges, but just enought to put a silicon gun, and sealed all around it. As a precaution, also checked front sunroof drain pipes, and one was clogged. I am sure that sunroof drains cannot cause water in trunk, but I will check them from now on, at least once a year. RR HSE 4.4 2006 LPG |
Yes, all sunroof drains are clear & door seals good. The tail gate seals are always the main issue, so replaced as a matter off course. keep the trims out until I find another trace of water. |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
I also had pretty much the same problem.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Do you have a tow bar fitted? I had water in the spare wheel well a few years back and the main cause was the rubber seal where the tow bar bolts into the body behind the bumper. water was just enough to soak in and track through and over time fill the well up. After slackening off the bolts and sealing behind rubber seal and the plate, tighten up and all was good with no water ingress. If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
Hi Weishdragon, Yep, done that. When I had the bumper off, I released the tow bar & used nearly a tube of silicone sealer, sealing everything up.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
I had same issues water ingress fried my amp and bluetooth. It was getting in through shark fin on roof and also the tailgate hinges. I applied thin bead of silicon around shark fin and caked load around the both tailgate hinges seems to have cured this common issue. Also im sure that both my rear arches have corroded over the years because of this water ingress as it rots from inside out and I have my car in bodyshop at the minute they have cut out all the rot it was shocking the amount of corrosion and they seem to think the same due to this water ingress going un noticed over a period of time. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Ok thanks guys - I dried my amp out and used an anti static brush and some contact cleaner (a can) got rid of all corrosion put it back in and it’s working. Now have a tube of pu glue on the way and a new eBay special shark fin that does dab as my genuine one is knackered anyway, i will do hinges at the same time and if any left I will do the top of the boot side windows Current stable:
Possible cause - on the opposite side but my drive slopes to the side of the leak
What’s interesting is the newer ones are cable tied should have done that before putting it all back Current stable:
