Home > Technical (L322) > Second battery
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
Second battery
Hello, new here and first post.
Can I ask, my 2006 has a second battery in the rear off-side cubby box. Looks like a pro job and not a DIY thing. Has anyone else got this.
Post #569636 12th Oct 2020 4:09pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I have In my 2010 tdv8
Post #569648 12th Oct 2020 6:41pm
Not fitted as original. Mine has a second battery fitted, can be very useful. DIY but pro. Thumbs Up Very Happy
Post #569652 12th Oct 2020 7:20pm
Billie
Thanks for that, good to know mine is not on its own. I presume it is for the entertainment side of things. Would I be right in saying, if I remove the main battery I will not lose the codes Question
Post #569687 13th Oct 2020 10:59am
I can only speak for my 2004 but when changing the battery no codes etc lost at all. I presume it is the same for all years as I've never seen a post regarding a problem. Thumbs Up
Post #569726 13th Oct 2020 5:41pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Re: Second battery
I would suggest it's "electrically unlikely" that removing the second battery would cause you to need to re-enter any codes, my logic being that the cars electrical systems are 12 volts and hence, the batteries must be wired in parallel.
Hence, removing one should leave the other one in situ and cause no issues! Smile
Post #569757 13th Oct 2020 9:11pm
There are no audio codes sir... Left them things behind with the P38 Thumbs Up
Post #569768 13th Oct 2020 11:42pm
Billie
"There are no audio codes sir... Left them things behind with the P38"
Having just moved up from the P38 I thought the code thing would be the same. Good to know it's not but I do have the "check coolant" message on the screen.
One way to rid a RR from the code system...
Post #569791 14th Oct 2020 9:33am
