Home > Maintenance & Mods (L322) > Replacing on the key fob a 2010 4.4 TDV8
Smp68
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
As you can see the cover over the buttons on my keys has fallen off. I ordered a replacement fob of eBay. I then used the pliers to pop the old fob open having opened both sides to get the pliers under the lips of both sides of the fob. It was then a case of moving everything I need to the new fob. I also moved the two metal pieces as they have the brand on them.😁 It was then just a case of pushing both plastic halves together.
Post #570006 16th Oct 2020 1:06pm
DrRob
Did you get the upgraded non rubber, hard case ? Way better than original issue Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #570032 16th Oct 2020 3:44pm
Smp68
It was the cheapest UK positing as I didn't want to wait for shipping from China. They all looed the same. Was £15 inc p&p. Didn't see the point of going LR original. Everything fitted fine and 5 minuters start to end. Easier than the previous shape and the case didn't break either so should be able to use again if wanted just need to cover the holes.
Post #570034 16th Oct 2020 3:52pm
from memory when we done it a few years ago the OE LR ones are around £8'ish.. ... - .- -.
Post #570035 16th Oct 2020 3:55pm
