Home > Maintenance & Mods (L322) > Intermittent Heavy steering
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys got a mad one here my power steering suddenly goes tight and stiff intermittently not always when it go tight it soon goes loose again once I force it to turn this doesnt happen at certain speeds either its a Radom one could it be my fluid as I checked it and its a dark brown colour!
Cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #570111 17th Oct 2020 8:58am
Mr Tee
Servotronic valve the likely culprit, worth a search
Post #570113 17th Oct 2020 9:15am
Dolphinboy
Mr Tee's right. If not that it could be the BCM intermittently failing (it's under the Pax seat).
Post #570160 17th Oct 2020 8:16pm
jaysta10k
To be fair I know about the BCM issue as my car is experiencing that as with rear doors don't open sometimes and the steering is very heavy when both doors don't open also.I can bypass this by quickly turning ignition on and off. My issue is that I get intermittent heavy steering when driving sometimes light and sometimes heavy resistance. When I rev engine at 3000RPM when stationary I still get this issue turning left to right full lock intermittent heavy resistance. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #570254 18th Oct 2020 7:14pm
