Home > In Car Electronics (L322) > 2010MY Camera specs? Interchangeability with L405 spec? |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 326 |
I've a broken lens on the front left camera on my 2011 (2010MY) L322.
24th Oct 2020 5:08pm |
Replying to my own thread, second sign of madness?
26th Oct 2020 5:15pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I suspect they use the same/similar camera system.
28th Oct 2020 9:00pm |
Yup, that’s what I thought - I’m also wondering if the lens portion itself is easy to swap. There’s an M12 thread used on many small CCTV or board cameras which I think might be a cheap way of replacing the lens when it gets stone chipped.
28th Oct 2020 10:01pm |
Camera appears to be analogue with the signal transmitted using LVDS.
17th Nov 2020 10:35am |
Yeah, they seem to be used on RRS's from memory, but still very expensive - I'm guessing all the cost is in the shape of the housing (as in they didn't use it for long and so it's more expensive), which is my logic for pursuing a retrofit of the later type cameras which are much cheaper.
19th Nov 2020 11:06pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
There’s a recent vid from powerful uk on this subject, worth a look |
20th Nov 2020 7:55am |
Thanks for the tip! I found this one on the reverse camera.
20th Nov 2020 11:47am |
20th Nov 2020 11:55am |
