Home > Technical (L322) > Yellow Restricted Performance - but no change to the cars pe |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4200 |
Could be a huge amount of reasons unfortunately...
25th Oct 2020 5:53pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
As Rob says a code is best if you can get one. Not knowing the icarsoft, I'd do what many do and invest in a GAPiiD if you intend to keep the FF.
25th Oct 2020 6:35pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I often get this just after I fill up with diesel. Tends to happen if I refill when the warning light comes on. After a restart it goes away. |
25th Oct 2020 7:12pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
This is the thing i get the warning and no change to the cars performance at all.
25th Oct 2020 11:41pm |
You need a tool that can read pending and/or historic codes.
26th Oct 2020 12:06am |
that could be it as the fuel gauge is faulty reads less than half a tank when full!!
26th Oct 2020 12:08am |
There is a fix for the faulty fuel reading. It's around fixing some wires in the tank....probably in the Wiki 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Oct 2020 7:59am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 224 |
Could be the water in fuel sensor. I´ve had to replace mine on both my L322 and D4. Same thing, yellow RP comes on intermittently but no effect on the cars performance.
26th Oct 2020 10:29am |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 73 |
You can buy the 3.6 fuel filter housing and remove the sensor and wiring from the back and transplant to the 4.4 housing on the car. There is a large difference in price as the 3.6 housing is £39, where the 4.4 is £250. So if you read the codes and get a p2264 it’s a much cheaper fix. |
26th Oct 2020 11:25am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Im currently having a similar issue where the warning triangle in yellow comes up on my TD6 with abs warning etc. No loss of performance etc and clears on restarting. Mine fault is the steering angle sensor and I have purchased a replacement one but seeing as its a pig of a job to do haven't committed to changing it yet. Interestingly the fault only occurs when the vehicle lowers after70 mph. If I lock the suspension at normal height I don't get the issue. |
26th Oct 2020 11:32am |
well i updated Icarsoft LRII today and have pulled code from the car. it does not clear either so i am ssuming the sensor is knackered. P0040D i have seen a few threads on here so am off to read them now |
26th Oct 2020 7:00pm |
That code usually has no effect on the car and is a pain to replace. You have probably read Greg's thread by now...I did have mine changed at Rovertune when they swapped out my secondary turbo.
26th Oct 2020 9:27pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3517 |
Thx Rob, yes that code won’t be it.
26th Oct 2020 9:37pm |
i did think boost leak and will check boost hoses.
27th Oct 2020 12:41pm |
