![]() | Home > Maintenance & Mods (L322) > MOT failure - brake pipes. Was this a reasonable price? |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 ![]() ![]() ![]() |
Just looking for a quick heads up. My car failed it's MOT last week-
Thanks, they had it for a week so I've been trundling around in a corsa |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
So they didn’t use any brake fluid during the job, but charged you for anti freeze? 🤔
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
As pointed out by jim4244 Antifreeze?, where did they use that?.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6824 ![]() ![]() ![]() |
I wonder what testable components were concealed by undertrays.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8091 ![]() ![]() ![]() |
Hard to tell whether you had a lax tester last year or an over zealous one this year.....
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 546 ![]() ![]() |
Having changed the rear cross over and front to rear pipe on my own cars twice (once each), I'd say that's a fair price.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 698 ![]() ![]() ![]() |
I'd be happy with that. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
Had the same with my 90 when it went in for MOT. Loads of advisories but it's only done 350 miles since the last one. A fair number (nearly all) of the advisories were not mentioned at all last year. It is as I have always suspected, MOT garages just want to find things to charge you for fixing. Ivan 2013 Vogue SE SDV8 2013 Freelander 2 SD4 HSE Luxury |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I had to have all my pipes replaced and it was over £1k
They should be good for at least 8 years, in my experience that's when the original steel pipes start to become a bit worse for wear.
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
I always take all my cars to an MoT test station that does not do repairs. They are not incentivised to find work. Also as they just do MoT's they see a wider variety of vehicles. I once had a local garage fail my MGB for excessive play in seat runners. They were like that the day they left Abingdon! And on the other side of things because they do so many tests they know what faults develop on what vehicles and at what rate so have a better subjectivity. I even have had instances where they have pointed out not MoT related jobs where they have pointed out things for preventive maintenance. |
I always take all my cars to an MoT test station that does not do repairs. They are not incentivised to find work. Also as they just do MoT's they see a wider variety of vehicles. I once had a local garage fail my MGB for excessive play in seat runners. They were like that the day they left Abingdon! And on the other side of things because they do so many tests they know what faults develop on what vehicles and at what rate so have a better subjectivity. I even have had instances where they have pointed out non MoT related jobs where they have pointed out things for preventive maintenance.
That's good advice ![]() I still think that the factory fitted steel pipes only have a safe life span of around 8 to 10 years. The rear cross pipe turns to rust at this age and the front to rear pipe tends to corrode at every mounting bracket where moisture is held against it. I was shocked how bad the F-R pipe was on my 2002 car when I replaced it - and it hadn't failed on that as the tester can't see behind the plastic covers. He actually failed it on the cross pipe and the short runs attached to the Flexi's on the rear lower arms. I replaced the lot of course, but found the main front to rear pipe was in a shocking state and could be broken / folded with complete ease under very light finger pressure. The car was probably 12 years old at that point. I've also had my 2011 car fail on rear brake pipes last year (I didn't do a pre-MOT) and again replaced the lot. This time the cross pipe was well past it, and once again the steel pipes of the flexi's on the lower rear arms were in a very bad way. The front to rear pipe wasn't too bad this time, but was starting to show reasonable levels of corrosion (again at the pipe clips). I replaced the lot with Cunifer and gave the replacement Flexi's several coats of zinc rich paint and Smoothrite on the steel pipe sections. 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
