![]() | Home > Maintenance & Mods (L322) > 2012 Fault - Cruise Not Available / Speed Control Module |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi there,
Many thanks,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2763 ![]() ![]() |
Yes, the bumper has to be removed. |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 641 ![]() ![]() ![]() |
...or maybe through the wheel arch ? Mike - MPx
Can anybody point me at the method or manual for this ?
Perhaps described as the adaptive speed control module. Attached is the wiring schematic.
Many thanks, -------------------------------------
Does anybody have either of the following documents for the L322 2010 onwards RHD ?
Many thanks GraemeS.
I don't have any pictures but the wiring diagram is attached. Mine wasn't originally fitted with ACC and there was a dummy plug in the harness socket clipped to the panel behind the bumper (nothing to do with the bumper) where the radar unit mounts and into which the radar unit's link harness fits.
Just checked the Fuses again #17 and #6 and they are good. So I was just wondering if there is anyway to get to the AAC Control Unit without removing the bumper ? Perhaps from behind the wheel watch liner ?
The radar unit's bracket is bolted to the front of part# LR020912 in line with its RH bracket. Some access might be possible from underneath the bumper if the front undertrays are removed, possibly if just the small RH triangular cover is removed. |
