Home > Maintenance & Mods (L322) > Cabin air filter box
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Hi I am going to change my battery soon. I have a 2011 4.4 vogue, I’ve noticed in the treads for battery change, that it helps to remove the cabin filter box. Can someone show/tell me how to do this please.
Post #572106 7th Nov 2020 6:26pm
rjff
Take off the engine cover and you will see the cabin/pollen filter housing towards the windscreen. It's about 600mm wide and there are two studs with 14mm AF nuts. Remove and pull the housing towards you.
Search for replacing the inlet donut hoses and you will find pictures of the area.
HTH Cheers
Richard
Gap IIDBT
Post #572107 7th Nov 2020 6:35pm
No need if you are just doing the battery.
There are several battery swap threads on here. When I did mine I just put the bonnet in service mode, took out the Wiring which was in the way and, bobs a close relative, managed to get it out. There is nothing that can't be fixed with a hammer😜😜
Post #572109 7th Nov 2020 6:49pm
Cavalier
Thanks so much for that
Post #572110 7th Nov 2020 6:49pm
Baltic Blue
Not the best of pictures, but here is B.B. with the box removed.
Post #572111 7th Nov 2020 6:49pm
