Home > Technical (L322) > 4 Zone Climate
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
4 Zone Climate
In particular 4.4 tdv8 but may be same/similar to 3.6.
Does anyone have diagram of heater matrix pipes to the rear heater core?
I have looked through the service manual but cannot find where they come from in the engine bay.
Post #572976 15th Nov 2020 11:48pm
mjdronfield
You’ve prob seen this already then. Can’t see much else....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572987 16th Nov 2020 11:03am
JNC
Yeh I saw that. Can't work out where those pipes attach near the engine bay.
Post #572989 16th Nov 2020 11:17am
JNC
So it would seem the coolant feed and return to the rear heater matrix are just taken from the front pipes.
Therefore my intermittent lack of heat to the rear must be at the rear heater unit itself.
Post #573077 16th Nov 2020 10:11pm
D3Jon
Is the auxiliary electric pump running? If that's failed you would see poor circulation to the rear matrix.
Also, I'm pretty sure that the rear heater controls operate their own electronic coolant flow control valve, which if dicky would cause issues with rear heating.
IID tool would be able to tell you what is / isn't working correctly.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #573261 17th Nov 2020 8:53pm
JNC
Im sure the pump is running. After much investigation on the vehicle and parts diagrams, I’m sure the temp is controlled by the rear matrix itself.
It has a feed and return from the front, which gets hot as normal.
Next step is strip to get to rear unit.
Iid tool shows no live values for any of temp/actuators. I assume that is due to being 10-12 MY.
Post #573264 17th Nov 2020 9:07pm
D3Jon
Ah, so if the supply pipe to the rear is getting hot, then that rules out the flow control valves in the engine bay.
I'm sure the IID gives Aux water pump status / current draw (I think I saw it on mine just the other day and I have a 2011). I'll have to have another look tomorrow for you. Maybe a firmware update is required on yours?
Your diagnosis to date does seem to point to the matrix itself, or some other local control valve on the rear matrix?
Good look with finding the fault, these things can be a pain at times.
2014 Disco 4 HSE
Post #573275 17th Nov 2020 10:45pm
JNC
To follow on from this turns out despite ruling out the crossover valve as I had only a few months ago repaired it, turn, it was still faulty.
I repaired again and everything seems to be back to normal.
Post #575414 7th Dec 2020 8:56pm
D3Jon
Glad you got it sorted, and apols for not getting back re. IID values - I forgot. But looks like all sorted now, which is cool Cool Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #575468 8th Dec 2020 12:08pm
