![]() | Home > Maintenance & Mods (L322) > Denso starter motor |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I'd stick with Denso. Most have on here with no issues...I think it's just a wear and tear thing... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
don't know how many miles your car's done (or more relevantly - how many starting cycles) but mine is still on original OE starter at 110k |
| Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193
42K miles but as you point out, I suppose it depends on the number of times the solenoid has been activated. Annoying when you think there is nothing wrong with motor, apart burnt contacts. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
Fit a new replacement, then strip and clean the contacts in your old one for a free replacement ready for next time it fails.
I did find a site today that sells Denso solenoid replayments. Could find one for ours though. But if they make them for lots of others, I wonder why they don’t do LR032541. |
Good luck with your search, but I don’t think you will find the bits we all need.
Further to my previous reply....
Managed to order a new Denso to day, good price, £200 using a £50 discount voucher. I will have a go at refurbishing the contacts on the old starter, see what they look like. |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
i had what i thought was a problem a click every now and then when pushing the button. turns out a battery charge and hold the button until the car begins to turn over problem solved. i think the issue in my case was releasing the starter button too early |
| All times are GMT |
