Home > Technical (L322) > Engine doesnt fire - L322 TD6 2003
Mads
Norway 2004 Range Rover HSE Td6 Bonatti Grey
Ok.. So a little problem with my L322 TD6 2003. Cold climate these days about 1 minus celcius in average. Anyways;
The Rangie were used last weekend, parked since sunday, tried to fire it up today with no luck. Turned the key over, «Pre-heating» came and the normal «bong» sound. Tried to start it and fires for one second before it dies. Sometimes it fires and stop, and sometimes its only cranking.
No faults are logged. Voltage dropped so hooked the car up to my daily driver (D3) to give it stable voltage.
Still no luck.... Any tips are more than welcome!
Post #574228 26th Nov 2020 8:42pm
Mads
Red off the live values and it seems like LpFP is doing what it sjould. Giving around 4.5-5.0 bar to the HPFP. The HPFP is also givg reading under cranking. So im guessing thats ok.
Post #574256 27th Nov 2020 7:02am
It could be that all the glow plugs have given up and need replaced. The engine would probably start even if just one was working. Even though you are getting the preheating message it would be worth also checking the glow plug relay is working correctly.
Should be one or the other.
Post #574320 27th Nov 2020 4:22pm
Mads
Thanks for the tip!
Took the engine covers off and measured the glow plugs; 12 volt are coming ttue the cables, and if I hook the plugs up to 13 volt from battery, they extremly hot.
Post #574376 28th Nov 2020 6:24am
Fox889
If the glow plugs get hot, could be the glowplug relay that's at fault? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #574381 28th Nov 2020 9:19am
Mads
Could, but im getting power to the glowplugs.
Post #574385 28th Nov 2020 10:00am
So the glow plugs get hot if connected to 13V directly?
Do they get hot if you put the ignition on until the preheat message appears and goes off?
Even if you have 12V at the glow plugs it doesn't necessarily mean there is sufficient power there to heat the plugs.
Post #574387 28th Nov 2020 10:28am
cass
Have you tried a squirt of "easy start" or similar?
It's not something I would suggest on a regular basis but I do find it useful to help fault finding
Post #574391 28th Nov 2020 10:48am
If you believe you have fuel, and glow plugs OK (but as NDFI says, car should start without them) then next thing to check is the wiring loom to the injectors, and do a leak off test on the injectors to ensure that fuel is actually coming.
When was the last time you changed the fuel filter? .
Post #574405 28th Nov 2020 1:01pm
Mads
Car is running again; were some cracked wiring to the camshaft sensor that were broke. Had to remive the plug and dig out the soldering iron to get it up and running. Now she starts om the first, wiers it didnt throw any fault.
Post #574464 28th Nov 2020 10:07pm
Well done Thumbs Up .
Post #574472 28th Nov 2020 11:21pm
