![]() | Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1420
Misfires?
| Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247
Are the coolant pumps common to go? Are they easy to source? I do have a whirring noise from passenger side inside the engine bay sounds like a bearing type noise, not a screeching or wobbling as such just like a rush or whooshing sound.
Got mine from amazon for about 100 quid, mine started to go at about 90k miles, it had been turning the wrong way most of its life, became apparent when booting it from 70mph to 80 or 90mph.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
If she's going into limp mode then hopefully a code has been stored in the car?
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I feel for you mate. I had a Ford Explorer that did similar things and it turned out to be a dirty connector on the crankshaft position sensor. |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
have you had the car scanned for codes?
At that price I will look in to it and tick it off the list of things done. its all a guessing game at the moment. Could be a hose or something small or something major I just don't know....main dealer perhaps!!!
Current Cars L405 Range Rover Vogue 4.4 Diesel Previous cars Lamborghini Gallardo 2006 Range Rover Vogue 4.2 V8 Supercharged Petrol 1996 Williams Clio 2 Aston Martin V8 Vantage Bentley GT Continental Porsche Cayenne 4.5s 4.2 V8 Supercharged Range Rover Porsche Boxster 3.2s Ford Kuga Nissan 350z BMW 316 Porsche Boxster 2.5s Golf 2.8 VR6 Highline Renault Clio 16v Vauxhall Nova GTE |
I have plugged it in.....it now comes up with sensor on bank one voltage low but I had the whole exhaust changed last Friday. i did this to eliminate the cats being the issue. It has fixed some of it but clearly not the root cause. I might bite the bullet take it main dealer and let them charge me £150 to plug in and tell me what I already know.
This is my point. I have ticked off major things and issue is still there. It will turn out to be a £30 hose but will end up costing me 3k to find this out. even going to a garage they say one thing then you do it and then it does not fix it. I was told it was a fuel pump then 95% it was the injectors.....neither have fixed it more has the new exhaust.
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Could be a case of swapping the wires over on the coolant pump. (Got the right car this time Stan)! Previous cars:
hi mate
| Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199
Ill think,
Had a vacuum test done and was told no leaks. I have totrust what I am told on that one but you could still be right.
| 4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185
The quality of the battery is key on L322 Range Rovers. Low voltage results in all manner of errors being thrown, that indicate other issues, when it is the battery that is the root cause.
| All times are GMT |
